A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563вопросов Показать все
2017 MacBook Pro Doesn’t Restart
I decided to upgrade the 128gb SSD on my Mac to the Sabrent 512GB Rocket NVMe PCIe M.2 using this adapter https://www.amazon.com/dp/B08RCMJJHX?ref...
I was able to format and install MacOS Big Sur successfully, however during installation the system wouldn’t automatically reboot instead just shutdown until I pressed the power button. Also when I restart from Apple Logo in the top left corner the system wouldn’t reboot until I pressed the power button and I’m thrown two errors that says, “You shut down your computer because of a problem” and “Your computer was restarted because of a problem.”
Это хороший вопрос?
Оценка 0
3 Комментариев
Put the original drive back in, does that work?
из
Yes that fixes the problem, so it’s definitely the 512GB SSD. Should I return the SSD and adapter for another brand?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sadly, here’s no options other than another Apple SSD as its a custom part!
Here’s one source Apple 512 GB SSD or Apple 1 TB SSD
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Alex Chung будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 134
