Keyboard FPC Connector Identification
Was wondering if anyone had an idea of what the part number for the Keyboard FPC Connector is inside the Pavilion 15-n097xx models. I am having one !&&* of a time trying to find the board component online to order so I can replace the connector…
Any help would be great!
The only HP ZIF connector I have their different styles but the same length and pins…. Would it work?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
The connector comes attached with the keyboard, there's no part number for it, I'd suggest you contact HP in your region regarding the service options for your computer.
Был ли этот ответ полезен?
Оценка 1
6 Комментариев:
Ill update my post with a picture of what I'm on about as i think you have misunderstood
из
Updated with an image buddy
из
This kinda helped, I now know it's called a ZIF connector, not FFC/FPC... I have uploaded an image of an X360 donor board I have here with a connector with the same pins and mounting points, but they're slightly different styles. Theyy both measure 4 CM in length, would this work?
из
Показать 1 больше комментариев
Добавьте свой ответ
Jon Williams будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 117
