Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
111вопросов Показать все
MacBook Pro camera no longer works after screen replacement
I busted the screen on my M1 MBP and after replacing it the camera, ambient light sensor and True Tone no longer function. is there anything I can do about this? from searching it sounds like an uphill battle. Thanks.
Это хороший вопрос?
Оценка 0
3 Комментариев:
Sounds like you got the wrong part. Where did you get it and what was the part number listed? (also compare the paperwork and the packaging)
из
I ordered it from iFixit, listed as "MacBook Pro 13" (A2338, Late 2020) Display Assembly / Premium / Dark Gray"
из
I should say, it was a complete display unit.
из
Добавить комментарий
1 ответ
Contact iFixit support for a parts exchange Contact iFixit Customer Support
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Rachael Julstrom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 242
