The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Horizontal coloured lines cover the screen when HDMI is not plugged in
Hi there,
I have a really puzzling issue with my MacBook Pro 2015 A1502. The screen is covered with horizontal multi coloured lines across the screen, it covers the entire screen so it becomes unuseable. I assumed this is a software issue, so I installed a brand new WD 500gb SN550 hard drive with a fresh install of Big Sur, but the problem persists. So I assume the issue is hardware related? however, if the HDMI port is populated the issue stops immediately, on. both the Retina as well as the external display, so I assume this isn’t an issue with the ribbon cable, could it be the logic board? or maybe the Base OS X? I fairly new to mac’s so I may be well off, but I’m pretty out of my depth at this point, any help or suggestions would be greatly appreciated.
i5 2.7ghz
8gb
intel iris 6100
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You do indeed likely have a logic board issue. The video signal has a complex pathway which it needs to travel
Some folks have found the load of a HDMI cable is enough to solve this and some have found replacing the internal display was needed as the loading of the signal was at fault from a bad internal display T-CON board.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thanks for your post. I may try replacing the logic board in the future, but as you say, that may not even solve the issue, as it may lie with the T-CON board. I currently have windows 10 running on it flawlessly no issues at all, HDMI port works. Do you think this indicates it a logic board issue rather than T-CON? I would love to use macOS but windows 10 will have to do for now. Thanks again.
из
@Matt - I need a bit more here... Windows works on your internal display with nothing else connected?
из
Добавьте свой ответ
Matt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 185
