Repair and assembly guides for the Honda General Purpose Engine model GXV160UH2.
1вопросов Показать все
Need general tips and advice for fixing up a broken lawnmower.
Hello, I need some general tips and advice for fixing up an old lawnmower. I haven't put any fuel or oil in yet and tried to fire it up, should that be my first step? If so what next? Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It depends. I would put some oil in it and it a couple of times by pulling the starter just to see if it is seized up or not. Give it a good cleaning. And check the blade to make sure it is on tight. Smell the gas to see if any left and if it smells bad. If it does pull tank and carb and clean. Check spark plug and make sure it looks OK. Then try to start it.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks man. I'll give that a try and see what happens and possibly ask another question or two ?
из
Ask all you want.
из
Добавьте свой ответ
Heinz Beanz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 86
