Trackpad glitch possible solution?
The trackpad seems to look and mechanically perform fine. However upon starting the computer, as soon as I touch the trackpad the cursor on the screen freezes in downpressed mode and I have to reboot the computer. Startup with a USB mouse attached and set to disable the internal trackpad works fine but I was wondering what could be wrong with the trackpad and if there might be an easy fix. The problem could have occured related to less than gentle treatment by a young child but that part is somewhat speculative. Thanks.
Это хороший вопрос?
Оценка -1
2 Комментариев
please give us the last three figures of your serial number to get you to the correct guide
из
SQ7. Thanks!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Apple PowerBook G4 1.67 15" (Al) Specs
Identifiers: 15-Inch 1.67/1.5 - M9677LL/A - PowerBook5,6 - A1106 - 2029
The trackpad is built into the upper case: [связанный продукт отсутствует или отключен: IF154-058]
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks, so I take it you think the trackpad, given it's explained behavour, is beyond repair, loose cables, dirt etc?
из
Добавьте свой ответ
Johan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 471
