Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211вопросов Показать все
A delay on typing happening on CAPS key, can it be fixed?
Found this issue on my MacBook pro 16” 2019 laptop recently:
There is always a delay for characters showing on screen when pressing “CAPS lock” key (when needs capital letter), it works fine after having the MacBook pro reset to factory settings, but issue came back gradually after installing apps like office, mail, etc.
Is there a setting to control this? Anybody has the similar experience or know how to resolve it?
Many thanks,
Tom
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I had the same issue and I thought that the reason was in my Magic Keyboard, but you can fix it by going to System Preferences -> Accessibility, then turn on “slow keys” and set delay to the minimum value in settings.
Был ли этот ответ полезен?
Оценка 1
I don’t think you have a keyboard issue, this sounds more like something is stealing your keyboards output (key-logger) so as you are typing the buffer is getting stuck as the output is not getting sent to the person spying on you!
I would run the onboard diagnostics to be sure you don’t have a hardware level issue. Restart your system and press the D key to enter. Review this guide Use Apple Diagnostics to test your Mac
You should install a good malware remover and anti-virus. That should get rid of any logger. You may also want to review your apps as some free apps are nothing more than spyware!
Оценка 0
1 Комментарий:
Hello Dan,
hardware diagnostics returns no errors. I will see if I can get a malware remover software installed and have it checked the logger.
Thanks for the help!
Tom
из
Добавьте свой ответ
Tom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 27
За всё время: 1,076
