Battery not charging, multimeter tests on mainboard
I suddenly found my Note 10 lite was completely unresponsive to charging cables, on or off, though was working fine with the remaining charge in the battery.
Initially thought it was probably the sub board with the mic, so changed it for a cheap replacement, but still doesn’t work. Now I’ve been playing around with the multimeter comparing it to this video: https://www.youtube.com/watch?v=IrwH55j8...
It seems sub board and the cable are ok, but if you go to 5:03 I don’t get anything with the same test on the mainboard (it does register when I check the other side of the port). Is it likely to be a broken solder? Is it likely there’s anything I could do to repair it?
Это хороший вопрос?
