Can I replace a 2015 retina display with a non-retina 21.5" display
Can I replace the 2015 iMac retina display with a lower resolution 21.5 2015 iMac display?
Это хороший вопрос?
Это хороший вопрос?
Sadly just like replacing tires you need to stick with the correct size!
As you can see here the display data cable is larger as it needs to carry more lines of data! The box is the exact same size between the two images.
So no you can’t swap it out.
Был ли этот ответ полезен?
A rookie question, but now I know. Thank you so much for that and the illustrated differences!
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 101
