Logitech G403 Hero button replacement not working
Recently I had the double click problem with my mouse and decided to fix it myself by replacing the left mouse switch. After I finished soldering, I plugged in the mouse and the left click button wasn’t working at all. This was my first time trying soldering. I’m wondering if I had damaged the pcb when I was desoldering the switch.
Это хороший вопрос?
2 Комментариев
Did you get the same brand and model of switch as what there was before?
из Andrew S
yes I believe so. This was the item I bought off of Amazon https://www.amazon.com/gp/aw/d/B085LB7FZ.... The serial number on the side of the mouse switch matches the one on the original. One or two of the solder pad came off I think during desoldering. Do I have to retrace the path and how do I fix the connection?
из Daniehd
