My monitor isn't detecting my graphics card
i was just using my pc normally and suddenly my pc just restarts and before I knew it my monitor stopped using my gpu I tried restarting and it didn't work I tried disabling the integrated graphics card in device manger and then connecting the cable to my gpu and it still didn't work pls help me
Это хороший вопрос?
7 Комментариев
Hi,
What is the make and model number of the PC or motherboard if a custom build?
What is the make and model number of the GPU card?
Is the GPU card still showing in Device Manager (or BIOS if applicable)?
If the GPU card has a fan is it operating?
из jayeff
My gpu is a gtx 750 ti 2gb and my motherboard model number is 339A but I will still check if the gpu fan is spinning so 1 sec
из Harry Jurtz
I couldn't find if my gpu fan is still spinning because the screws are tied so hard that my screw driver couldn't even open it
из Harry Jurtz
@Harry Jurtz
Can't you just feel or hear if the fans are turning in the GPU card or are you talking about the PC case screws?
Presumably a HP motherboard?
Did you check Device manager or BIOS to see if the GPU card is showing there?
из jayeff
@jayeff well it doesn't show up for device manager but I will check for Bois now
из Harry Jurtz
Показать 2 больше комментариев
