shut down screen pops up?
I have a Ibook g4 1.42 with an 80GB hard drive 1.5GB DDR RAM,and has a new battery. I'm running tiger on it and it runs really good the problem is I get a little black screen that pops up and tells me to restart using the power button. This happens often and while I've been on the computer for about a hour or less.
Why does this do this and how can I fix it?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
The black page that pops up is a called a "kernal panic event", a message sent by the computer to warn you that there's a software or hardware probleme occuring. It could be a lot of issues but in your case if you still have the machine original hard drive from 2005 I would suspect it to be the culprit but I could be wrong. Does it always happens when using the same application or do you feel the computer is overheating ? Ram issue ?
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
+ Nice answer
из
I have found the cause of kernal panics to be memory more often than not. Since you have checked out lemerises answer without success I would try checking out your memory. + to lemerise and AB
Оценка 2
Добавьте свой ответ
Trevor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 957
