Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Apple logo blinking and red screen
Hello, i have an ipad mini 2 wifi. The battery was defective and i replace it. Once I turned it on the apple logo started blinking and a quick red screen comes then it keeps blinking the logo.
Tried hard resetting and made no difference.
Tried connecting it to the computer (iTunes), no effect.
Re opened to check the battery connection, no effect.
What could it be? Thank you.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like the Red Screen Of Death. Was the iPad at least booting with the old battery? If it was then try putting the old battery back in the iPad and see if the problem persists. If it boots with the old battery then your new battery may be defective and is causing the iPad to go haywire. If it still does it then its very possible you damaged the logic board when removing the old battery or putting the new one in.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kenneth Roman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 183
