The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
My xbox is lit with a single red dot
When i turn my xbox slim on it lights up with a single red dot in the center and the screen is black. Before the red dot appeared, my console would freeze at a constant rate. I would appreciate any enlightenment on this issue.
Это хороший вопрос?
Счет 60
32 Комментариев
Keep in mind that the red dot of death is not onlyonly caused by an error in your xbox360 Slim but can also be caused by an error I ur power adapter. If the power adapter light turns red after a few seconds or minutes, then the problem may lie there. If red, replace your power adapter to determine if it gives you the solution to renewed functionality. Otherwise if your warranty is still in good standing, seek out the R MA and return it to Microsoft. If neither of these solutions are an option for you, then click on the you tube link to follow it to a possible xbox360 Slim repair solution. Happy Gaming.
из
My light on my console turned green for a few seconds then red my power ADP went from yellow to green to yellow when powering on I took my heat sink off scraped all the sink clay into a pile on the CPU put my sink back on fixed!!!!
из
I have the same problem with my X Box.I also had the black screen with a red dot in the middle of the power button
из
for the red center ring. xbox 360 slim
из
Показать ещё 27 комментариев
Добавить комментарий
12 Ответов
Выбранное решение
Alex R, the only thing that I can come up with so far is the RDOD (Red Dot of Death) If you are still under warranty, notify Microsoft and see what you can do to get your console replaced. If it is not under warrant, check the optical drive. Apparently it can cause the RDOD :-)
Check out this guide on replacing the Optical Drive:
Xbox 360 S Optical Drive Replacement
If that doesn't work, peruse the Xbox 360 device page for more solutions:
Xbox 360 S
Also check Youtube for some decent explanations. Good Luck.
Был ли этот ответ полезен?
Счет 11
2 Комментариев:
October 6th, 2016 I'm getting this problem. Your solution is the best choice in my situation because I was having an issue with my Xbox 360 Elite having an issue reading "Dark Souls". I had installed the game onto the hard drive in order to bypass it's reading. I was hoping that would be the end of it (having to install the games), but no luck on that. It worked for awhile, then it started freezing. So I'll have to try this out. If I have any issues I'll post here for an update. If I don't post anything else, then this solution was perfect.
из
Do i need to change the optical drive or just get it off the xbox and is the optical drive the same dvd drive
Sorry for my bad english language
из
Before you go getting all complicated try this. Take your vacuum hose and brush and attack all of the vents. When you get to the one that the fan sits under take off the brush and position the hose over it till the fan spins. Let the fan spin for a moment. After awhile when the CPU cools try starting it up. This has worked several times for me. The better solution is to clean it before this happens.
Счет 10
2 Комментариев:
Thank you for this post. I have a second hand xbox because we have gone through so many new ones that "fall" off the cupboard. So I was freaking out thinking noooo not again and then I read the posts above and thought OMG are you kidding. Then I read this one. So I put the fan on the xbox, moved it to a new location, vacuumed it thoroughly and bang it works. Yay thank you so much. Didn't want to buy another one this close to xmas. Appreciate the down to earth, worlds not ending response you provided.
из
I am astonished that this worked for me. I ran my vacuum hose over all the vents. I couldn't see that it was doing anything, but when I plugged the Xbox in again it worked perfectly!
из
The unplugging of the fan reset worked. I did replace the thermal compound. But did not put in any new washers or bolts. Just used the old x clamp. And I went from black screen with red dot of death to playing the xbox an hour later. Just watch the you tube video above. I got this xbox for free to is the best part because someone was throwing it out!! :)
Счет 3
2 Комментариев:
I'm glad you got your Xbox working. That reset works more often them most, especially for the xbox 360 Slim.. Please give the video a good rep and share when-ever possible so that others can be informed about another possible option to a suspected broken xbox, that might not be broken at all.
из
Last night I got home from work and tried to play madden, and it's started up logged into my account and clicked the game, and after it's said EA Sports and froze. Tried to turn it off by the remote but didn't work. So I just $@$* it off cuz wouldn't turn off when I did it with my remote. And then turned it on again and showed a red dot. It's a refurbished Xbox my lady got for me in April, only had it for about 4months
I don't know how to take it aprt and don't wanna mess it up.
Can sum one help me solve my problem? Plz
из
Try this guy..
http://youtu.be/0xWCD0-mTC4
Счет 2
I contacted xbox because I have the solid red ring, red dot and the blank screen. They informed me to get a new power cord first instead of sending it in for repair.
I am sure the fan is not working because I does not spin when I cut on the console.
The tech guy said the power cord may have been overheated and may not be able to sent enough juice to power the system fully
Счет 1
2 Комментариев:
It's the southbridge apply press to it and bam it will fire up. Reflow the southbridge and Gpu/CPU should solve the issue.
из
I have an Xbox 360 S but I've never had mine freeze before. However, I think I might have a solution to the Red Dot. I saw in a video that the red dot is caused because the console has a problem detecting the hard drive. The guy in that video said that "The Xbox was pushed a lot during transit and it won't work because of that" and you might have shaked or moved it to convey the same error. In the video, he took the hard drive out and put it back in again, and that seemed to do the trick. I hope that solved it! :)
Счет 1
2 Комментариев:
That's NOT correct my Xbox 360 slim will boot with or without the hard drive. and i have tried it on 1 other system with the same result
из
This worked for me, thanks!
из
try uplugging it for two or three days and it will work, or also take it apart if its not under warranty and let it run for 5-10 mins. then put the case back on and it should work like new.
Счет 0
Hey Alex,
Within 10 seconds of turning on my Xbox 360 S, even after not playing it for days, the light goes from green to red dot. No screen image or error message. Here's what I've tried to fix it but nothing has worked yet:
Checking power cord and box, and using a brand new one,
Checked all inner and outer cables/connectors,
Pulling out 250 gb hard drive, shaking and putting back in,
Taking Xbox apart and cleaning all dust from it,
Taking out hard drive and trying to boot,
Taking out CD drive and booting,
Replaced the fan with a Whisper quiet,
Unhooked the fan and let Xbox overheat so as to reset it (did exactly as DB said in his excellent video).
I've now got my heat sync and chip apart and will buy Arctic Silver 5 today and re thermal paste the chip and reassemble. I hope it works but don't expect it will because the red light comes on so fast, there's no time for it to be a heating problem.
If any serious tech out there reads this and can offer something likely to work, please do. I have no warranty and the box is about 3 years old (but has been well taken care of, well vented, cleaned, etc.
Update (02/20/2016)
Okay, I did the Arctic Silver thermal clean and replacement idea and still a red dot. Now I'm trying the DB overheat reset idea again.
Счет 0
7 Комментариев:
Hi it's the south bridge that causing the issue. Maybe the CPU/gpu but most the time it's the south bridge needs reflowed. And don't use Arctic silver 5. Not the best pasted everybody thinks it is. Mx-4 is the best stuff to use. Might be one of the Rams too under the heat sink. Those are the things to check/ reflow.
из
Thanks Robert!! Will take your advice and look at south bridge, rams, do reflow
из
Tony, have you figured out the problem yet.
из
What is reflow southern bridge
из
How do I reflow and where is the southern bridge tried everyrhing tony did
из
Показать ещё 2 комментариев
Hey everyone. I just had the same problem. The Xbox 360 Slim froze about once every 15 minutes for about 30 seconds. I was playing on system link, and there seemed to be no issues. I woke up the next morning and turned on the console. It lit green for a second and then went constant red. Every time I restarted it it went red after half a second. I fully dismantled the machine and took off the heat sink, and heated the processor up to about 100 degrees (With a hairdryer). I tested it and the light was then green (It overheated quickly because the fan and heat sink were off.) I have fully reassembled the machine and it works great - no red lights. It may have started working because I readjusted all the connections inside the box e.g. Optical drive, hard drive ect. I didn't find anything super helpful on the internet, so I hope this helps.
Счет 0
1 Комментарий:
Check your resistors near the gpu heat sink there's five of them r4d8 r4d7 r4d6 r4d5 r4d4 .usaly this is the main problem of red dot .if faulty take them of either a soldering iron and use a thin copper wire solder this onto were you took resistors off this will sort your red light issue.
из
Try this first make sure you have no flash drives attached to any of the USB ports if you do remove them and second make sure to reseat the hard drive if you have one by removing then place it back in again now start up the Xbox 360. If still red insert a game disk close the tray now shut off and now turn it on again that should fix it something about the game in first and no flash drives before starting usually does the trick.
Счет 0
I unplugged my xbox but it still goes red please help.
Счет 0
1 Комментарий:
@nathansgliz start off by doing what user Tony did. If that does not work for you, go with the suggestion left by craige Craig channel
из
I've done everything on my Xbox 360 slim and it still has a little red light in the middle please help me.
Счет 0
Добавьте свой ответ
Alex R буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 22
За последние 7 дней: 128
За последние 30 дней: 788
За всё время: 498,049
