iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
873вопросов Показать все
Battery issues after housing replacements
We’ve repaired housings on iPhone’s for quite a while now, all of a sudden recently we are finding that we are having battery issues after repairs, it seems isolated to the iPhone 8. Even if we change the battery with other used genuine Apple batteries we still have the same issues, I’ll list the problems below;
1) Phone charges really quickly. 2) Battery life drains rapidly. 3) When we attempt to drain the battery they die at around 3% rather than going down to 1% and turning off. 4) When we attempt to charge them back up from dead, they immediately turn back on rather than taking the usual amount of time to turn on and are sat at 3%. We try different batteries every time and its the same issues. I’m thinking board problem but its happening quite often and I’m wondering if its the techs are doing when changing the housing or if we are just getting unlucky batches.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
First thing I would check is to ensure that any grounding components for the logic board are installed exactly as they were removed. If they are lost or neglected to be reassembled properly this could cause issues.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Luke будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 27
