The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
Вопросов 5 Показать все
Stuck on starting windows screen
Hi my laptop is stuck on starting windows screen really slow to start up
Это хороший вопрос?
Оценка 0
1 Комментарий:
How slow is it? Is the OS installed on a hard drive or solid state drive?
из
Добавить комментарий
Ответов (1)
Factory Reset:
You could try to do a factory reset on the computer (you can find it in settings and lookup factory reset) but before you do make sure that you backup all of your important files/files you would want to keep(Photos, Documents, etc.) because it will delete All of your files
Upgrading to an SSD:
If your computer has a hard drive, you could try to upgrade it to an SSD which will make loading times much faster but also make sure to backup and/or transfer your files to the SSD
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
John James будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 233
