Short on LogicBoard - Please help identify the circuit
I got this iPhone SE 2020 from a friend of mine for Data-Recovery after a liquid damage. First I got a short in the Power IC Chip at the center of the picture (APL1092). After changing this one, there seems to be another short on the board. This time I don’t know where to inject voltage, can someone help me with this line? (I marked the Diode-Mode-Shorting out Caps in the picture.)
Update (24.10.2021)
The picture
Это хороший вопрос?
7 Комментариев
inject into the battery connector first and see what current it draws.
из daniel
@tech_ni Unfortunately there is nothing going into the board from battery oder the lightning connector.
из Adrian
i have wxj software but unfortunately it doesnt show line names for the se2. it could be low resistance lines that seem short but actually are fine. have you any photos of the actual board you could post.
из daniel
@tech_ni no low resistance, I've got 0,2 ohms ...
из Adrian
Here is a picture from the actual board. I‘ve tried to input voltage but its getting right to ground. Nothing on the board seems to get hot. It drops from 1V to 0,8V with 2Amps, should I give it more? I think it might be a layer-short or sonething like that … [image|2503942]
из Adrian
Показать 2 больше комментариев
