Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
71вопросов Показать все
Are the batteries glued in?
Are the new 2021 14” MacBook Pro’s batteries still glued into the case like with previous models? Or have they improved the battery replacement story, alongside the other “pro” improvements they've made such as re-introducing the HDMI port and SD card slot?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
The battery on this model has pull tabs that make it easier to take off the adhesive.
Был ли этот ответ полезен?
Оценка 7
2 Комментариев:
It's still a bit early, I've not seen any clear teardowns on the battery yet.
I'm sure the iFixit team will give us a good detailed teardown soon!
из
İt does have pull tabs
из
Добавьте свой ответ
Mark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 3,114
