Why will only the driver side window roll down? 1998 Camry LE
When I try to roll the windows down from the driver side only the driver side window will roll down. I was able to roll down all windows before?
Это хороший вопрос?
Оценка
0
Do they roll down from the switches on each door? And just the drivers switch doesn't work for them? If so, there's either an issue with the wiring to that switch set, or with the switch itself.
из brandon k
