Released by Nikon in January 2014, the Coolpix L830 is a compact digital camera designed to provide powerful zoom with simple operation.
Why It only turns on with the power supply?
Nikon coolpix L830 started to place messages , card can not be read., i turn it off them On and it worked.
Now the camera does not turn on with the batteries , I plug it to the power supply and that's how it works.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
batteries can be bad enough that they appear to be fully charged in the charger but have such a high internal resistance that the terminal voltage under load won’t run anything. If u really want to test it u must put a load across your DVM probes and connect to the output terminals.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
How i do it? A have a DVM and i have try several testing. Batteries are new and the charge is ok.any other tips?
из
Добавьте свой ответ
Angel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 193
