2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
572вопросов Показать все
The fans go on max for the simplest of demands
I have a MacBook Pro (Retina, 15-inch, Early 2013)
2.8 GHz Quad-Core i7
16GB Memory
768GB SSD - 26% is available
NVIDIA GeForce GT 650M 1 GB and Intel HD Graphics 4000 1536 MB
The fans go on max for the simplest of demands, like surfing the web. If I edit a video on battery the device will get so hot it turns off.
I have:
Changed the thermal paste
https://www.amazon.co.uk/gp/product/B011...
Changed the battery
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Sprayed it with an air duster
https://www.amazon.co.uk/gp/product/B000...
Changed the left and right speakers - This was due to them not functioning
Changed the trackpad - This was due to it no longer clicking
What would you suggest I do, in order to prevent the system getting so hot. It seems the CPU Cores get extremely hot very easily.
Это хороший вопрос?
Оценка 0
2 Комментариев:
Sadly, I have exactly the same thing on my 2015 2.8 model. Seems there's no way. Only Volta can somehow help you lover the voltage on CPU and make it relatively sane. But GPU is whole onther story, and as soon as it gets involved - fans on max are guaranteed
из
Looking at the TG Pro it appears the battery has an issue. Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see
из
Добавить комментарий
2 Ответов
I noted the CPU temps seem high given the lower temps at the heat sink fins. I’m thinking your heat sink has failed. When you where cleaning did you done any oily spots on the logic board where the heat sink tubes pass or see any white dust stuck along the tubes. MacBook Pro 15" Retina (Late 2013-Mid 2014, Integrated Graphics) Heat Sink and MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink as well as the guide MacBook Pro 15" Retina Display Late 2013 Heat Sink Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2014, Integrated Graphics) Heat Sink Изображение
Продукт
$19.99
MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink Изображение
Продукт
$19.99
Был ли этот ответ полезен?
Оценка 0
Этот ответ изначально был на другой вопрос.
Did you actually remove the motherboard? There is a few screws that hold the heat pipes and fin array to the motherboard. these have to be just tight enough to not allow it to back off. Also if it did come off somehow you probably just need to replace the thermal paste after you clean off the old paste. the old paste dry’s out and if the “seal?” is broken almost never reseats well enough without replacing it. clean old stuff off with alcohol and qtips. Also check the fins around the outside of the fan. These can get a layer of dust that you can’t just blow out and sometimes requires manual removal.
also when you put on the heat sink each screw should be about the same tightness. if even one screw is to tight you will only have a partial connection. You should also tighten in a cross or star pattern so you have the same tightness on each screw.
My guess is that you have one side to tight so the other side of the heat plate doesn’t get down enough.
Оценка 0
1 Комментарий:
Добавьте свой ответ
Tazer Presland будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 56
