WHY DOES MY toyota camry make loud rattling sounds when traveling on
When hit bumps my 2000 toyota camry has loud rattling sounds coming from underneath the vehicle
Это хороший вопрос?
Это хороший вопрос?
Where is this sound coming from. It could be a number of issues. First thing I would look at is ballpoint
Был ли этот ответ полезен?
This is something you'll need to go under to check. Try to narrow down an area where it seems to be coming from if possible. Ball joints, exhaust mounts, basically jack that sucker up on jackstands, get underneath, n see what moves. Check the exhaust, suspension, and steering components. If it is actually under the car (not around the engine compartment) then it is probably exhaust. Alot of exhaust systems use rubber components, and these can fail and make your exhaust rattle around.
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 24
За всё время: 988
1 Комментарий
I will do that as soon as I find a location to do so. Mahalo nui loa
из Linda Kalakau
