A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
161вопросов Показать все
Can power supply fuse (F12.5A) be replaced wih a 12A fuse?
The F12.5A ceramic fuse for 700 watt ATX power supply is blown, I think it may have been because of an accidental short. I have searched widely and although different sites list the fuse, no one has one and seem to indicate that the fuse is no longer produced. Would a 12A fuse work or is that half amp a deal killer? The load would be MB, 3 HD, 1 optical drive. Video would not be a gaming one.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Yess O.5 amp lower is acceptable, make sure to test fuse by checking its continuity through a tester meter always before installing it.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
hadn't thought about testing the fuse - useful!
из
Наиболее полезный ответ
Lower is fine but NOT higher.
Оценка 2
Добавьте свой ответ
Jim Lindemann будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 319
