loud noise on rinse and spin cycle..what can I do to fix this
2016 samsung washer makes loud noise while in rinse, spin cycle..what can this be? and what i can do to fix this…
Это хороший вопрос?
Это хороший вопрос?
Check the drive belt and maybe replace it
https://www.amazon.com/Samsung-DC66-1017...
Also if the noise is only when water is on it maybe the valve getting stuck from calcium depost and soaking it in CLR should fix this. Also run some CLR and water only and stop it mid cycle before it drains to clean these deposits out. than run 3 hot cycles empty to wash the CLR away
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 44
За всё время: 1,843
