AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65вопросов Показать все
How to open the magsafe adapter brick?
Hello, i know its a hard work and it will be a lot of cosmetic damage to the brick of the magsafe, but how can i easily split the case of the magsafe, to solder the wires again?, also i'd like to do minimal cosmetic damage to the charger, thank you :)
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
These things were not built to be opened as there are really no serviceable parts. I've used a Dremel type tool with a cutting disk to get into them with minimal damage. I cut along the seams.
Был ли этот ответ полезен?
Оценка 4
Добавьте свой ответ
Dario будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,507
