What is causing a yellow smudge across the bottom of pictures
Yellow smudge across bottom of screen on my Z712 IS
Это хороший вопрос?
Это хороший вопрос?
I’d recommend viewing the pictures on a computer to see if the smudge transfers to that as well. If not, it’s most likely just going to be a problem with the viewfinder. You’ll probably be able to find the part pretty easily. If it does show up on a computer, check the internal components behind the lens and make sure that they are clean.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 16
