1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
Is it possible to disconnect only the trackpad?
I’m having problem the keyboard and the trackpad, it’s freezes. Sometimes SMC reset does the trick, but after awhile it will freezes again. I’m looking through boot log and got this:
(IOHIDFamily) Invalid digitizer transducer
So I’m just curious is the touchpad is the one to blame? And so I want to disconnect the trackpad without disconnecting the keyboard. I see 4 cables on the trackpad:
  1. ??
  2. The cable to the mainboard
  3. The cable to the keyboard
  4. ??
What is cable number 1 and 4? Curious if these cables are the actual trackpad cable, and wondering can we disconnect these cables?
Это хороший вопрос?
Оценка 0
1 Комментарий
1 - Y signal inputs from trackpad
2 - combined signal connection to logic board.
3 - Keyboard input
4 - X signal inputs from trackpad
The logic board converts the analog signals to digital ones the main logic board can understand.
из
Добавить комментарий
2 Ответов
Выбранное решение
I bring the macbook to a local repair shop, they were able to identify a transistor that malfunctioning in the motherboard, and after replacing it, the trackpad and keyboard works fine.
Thanks for your reply @danj !
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
The trackpad has three functions
  1. The Trackpads input and decode
  2. Keyboard input and decode
  3. Connection for the signals to the logic board
In your case the decode logic is damaged within the trackpad, you’ll need to replace it. Your keyboard won’t function without the trackpads decode logic.
MacBook Air 11" (Mid 2011-Mid 2012) Trackpad
MacBook Air 11" (Mid 2011-Mid 2012) Trackpad Изображение
Продукт
$29.99
Оценка 1
3 Комментариев:
Thanks for your reply, I'm ordering the trackpad now
из
Just installed the new trackpad, sadly still the same, even the error log still said the same thing (IOHIDFamily) Invalid digitizer transducer.
Any idea what should I do next?
из
Добавьте свой ответ
Tri Emil Alim будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 58
