WiFi switches from Off to Connecting
Hello guys
My MacBook Pro has the following symptom: When using WiFi I face a problem that it deactivates itself and constantly tries to connect. As I have already replaced the WiFi antenna of my system I want to know if that maybe is a software related issue.
Someone who know what is the cause of this problem?
Это хороший вопрос?
Счет 0
1 Комментарий:
If you are within in direct line of sight of the AP what is your signal level (bars)? And is it stable then?
What is the distance to the WiFi access point (AP) do you only have one or multiple units either extenders or mesh?
What has changed? Did you replace your router or AP units? Did your system get damages somehow?
из
Добавить комментарий
