The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
50вопросов Показать все
Blank screen after battery replacement
Replaced the battery i n my Samsung S10e, checked that everything was working properly, which it was. Ran the battery down to 0% as instructed to calibrate the battery. Once plugged into the charger, my screen is no longer functioning. The battery has charged, and the phone will turn on, but the screen stays blank and unresponsive. Screen is physically undamaged.
Это хороший вопрос?
Оценка 3
1 Комментарий
Having this problem as well. Did you manage to find a solution?
из
Добавить комментарий
3 Ответов
Выбранное решение
Was suggested by someone to disconnect the new battery and plug in the old battery. I did this and the screen worked again. Unplugged the old battery and plugged the new battery back in and the screen is working.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Tried this to no avail. I can see on scrcpy that the phone is working, but display is black as ever. Tried reseating the display connectors as well, no dice.
из
Наиболее полезный ответ
There is the chance that the screen connector became disconnected during the repair process. You’re looking at the connector shown in step 23 of this guide:
Samsung Galaxy S10e Screen Replacement
Оценка 1
2 Комментариев:
Hi Jacob,
Thanks for your comment. I did check that the display connector. The display worked when the battery was initially installed. It only stopped working after the battery drained to 0% and I tried to charge it.
из
@Jeff Mcgrath Not a problem! Did reattaching the old battery allow the phone to work again?
из
I applied too much pressure on the screen after reattaching the back panel with glue. Screen died Blackout forever
Every morning my alarm rings out loud. However its a blank black screen. Only the physical buttons work to turn off the alarm
I did a hard reset. Even flashed stock somehow and nothing worked. Such a sensitive screen
Оценка 0
Добавьте свой ответ
Jeff Mcgrath будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 65
За всё время: 1,411
