The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263вопросов Показать все
Indicator blinking orange, no power
I am also having the same problem after i opened mine since blowing didn't work. i have checked all the connections and looked at the connectors on the battery bit (black and red are in) is there any other way to fix this problem?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If you plug in the charger into the wall and an orange light indicator appears, try a different outlet. If that doesn't work, try using a different charger, but if that doesn't work then I don't know.
Был ли этот ответ полезен?
Оценка 1
i am having a simalar problem. my dsi got mountain dew spilledf on it and it wouldnt work any more. So i realized the batery fried and threw it away. Now whenever i plug it in it blinks the orange light. i just ordered a new batery from amazon. that should do it.
Оценка 0
Добавьте свой ответ
jamester1991 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 2,010
