Wi-Fi connection after update
My iPhone is only connecting 5ghz Wifi. I can’t connect to any 2.4ghz Wifi.
Это хороший вопрос?
Оценка
0
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 39
Did you reboot? Also reboot wifi router at same time. Turn off phone than reboot wifi router
из stressmaster
I did. It doesn't work.
из Omar Attia
@Omar Attia can you connect to other 2.4ghz wifi? Also did you tell phone to forget the old wifi?
из stressmaster
@stressmaster Unfortunately, I only can connect to routers that support 5ghz Wi-Fi. I can't send even a hotspot to any device until I change the hotspot band to 5ghz.
из Omar Attia
It is possible the wire that is the 2.4Ghz in the phone came loose. Or the board has a chip or resistor/transistor burn out.
из stressmaster
Показать 3 больше комментариев
