Wiko Pulp 4G — это смартфон среднего сегмента с неплохими функциями и техническими характеристиками. Он оснащен 5-дюймовым дисплеем с разрешением 1280x720, 13-мегапиксельной камерой и четырехъядерным процессором с тактовой частотой 1,2 ГГц.
Wiko pulp 4 won't stay charged long
Why won't my wiko pulp 4 stay charged long? And why is it so slow
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Try replacing the battery. Even rechargeable batteries have a lifespan.
Here’s the Ifixit Разборка Wiko Pulp 4G guide, that shows how to remove/replace the battery.
Replacement batteries are available online. Just search for Wiko 5251 battery to get results for suppliers.
As for why it is so slow, try the following and check if trying them causes performance to improve:
Wipe the cache partition and check if performance improves. Use the link to get into the recovery mode and then use the hardware keys i.e. Volume to navigate and Power to select to start the wipe cache partition option.
Start the phone in safe mode and check.
If it works better in safe mode, then a downloaded app is the cause of the problem. You need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to see if it works better. Once it does then the last downloaded app that was uninstalled was the cause of the problem. A downloaded app is one that you downloaded and installed on the phone and was not pre-installed on the phone when you first got it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Tabitha Foote буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 25
За все время: 535
