Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330вопросов Показать все
Disk Read/Write never gets above 20MB/s until I Run BlackMagic.
My late 2012 27” i5, without an SSD got very very slow. Disk Read/Write never gets above 20MB/s with normal computer usage until I Run BlackMagic, when disk is capable of hitting over 80MB/s . CPU use is minimal, ram is free and so is disk space.
Looks like something is throttling the system disk access, so anything i do is painfully slow. Apple System Diagnostics shows no errors with even the most thoroug scan, surface scan prooved no errors and so did fdisk -fy from single user mode. Heck, what else could I do except trying to run it from an external ssd installed system?
Это хороший вопрос?
Оценка 0
2 Комментариев:
What is the version of OS you have on your system?
из
I'm on Mojeve now, but things heve been going downhill since previous versions. I did not pay too much attention to it as I've been mostly using it for leisure and my MBP for work for a couple of years, but I could use the bigger screem now but it appears unusable for any serious task.
из
Добавить комментарий
1 ответ
Well I’ve got some bad news ;-{
This macOS version don’t work well on HDD’s as it runs the newer APFS file system and currently there is no means to defragment the HDD like we could with HFS+. It was designed to run on SSD’s which work on a block basis not cylinder/sector a HDD works off of.
So to fix this you will need to backup your drive (TimeMachine), then reformat it and install a fresh OS onto it and then restore your user accounts, apps & data (Migration Assistant).
The other approach is just bite the bullet and get a SSD swapping out your old spinning rust drive.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
That's not such a bad news, after all, it's the first in some time that's worth diggin into. I'm only wondering, why would black magic succeed in reaching higher speeds, whilst everything else would be in slo-mo?
из
@Piotr Kocybik - The drive is used for caching and virtual RAM. How the application runs between the two drives is what you are seeing. The difference between of how your HDD SATA III (6.0 Gb/s) drive and the mSATA blade drive which is also running at SATA III (6.0 Gb/s).
из
Добавьте свой ответ
Piotr Kocybik будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 143
