The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299вопросов Показать все
iPad only pulling .30 amps?
I have an iPad Air here that won’t power on or react to anything. When plugging it into a voltage reader it shows that it’s only pulling .30 amps, which is obviously way below what it should pull. I’m assuming this is caused by the battery or charge IC. Anyone know anything deeper about it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
One solution that is very common is that the charge port is full of dust. Another common problem is that the battery burnt out. iPad Airs have been out for 8 years so the battery is probably only working with 50% capacity by now. I’d wait for someone smarter than me to answer first though.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Lol got it, thanks
из
Добавьте свой ответ
cleb будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 25
За всё время: 166
