Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Вопросов 20 Показать все
Screen not working after brightness turned up?
I got a 6s recently off a friend with a dead screen. They had replaced it along with the battery but after they finished the screen would no longer light up, although the phone was on and would connect to a computer just fine.
It was sitting for just over a year before I got it, after some looking I got the display to work by disconnecting the selfie camera assembly, it was very dim but the back light was on and everything worked fine.
Later the next day I took it to them to get their icloud account removed or any data they wanted, after putting in the passcode we tried to turn up the brightness on the display, as soon as we did the screen went blank but the phone was still on and working.
I have tested that screen on a icloud locked 6s and it worked just fine along with the home button, I have also tried other screens both apple original and aftermarket along with working front facing camera assembly’s all with the same result of a blank screen but the phone vibrating/charging and connecting to a computer though the phone needs to be unlocked for anything to be done.
I have not tried to wipe or update the phone since it is running some version of iOS 13 that I would like to keep on the phone if possible and my friend has some pictures on the device they would like to get.
The only thing I can think of that would be the problem is the main display connector is damaged but was in this state when the phone’s display first worked, I have put a few photos of it below in case anything can be made from them.
Thanks for reading and any help is much appreciated.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Hi,I am not entirely sure of what the problem is but from the photos you have uploaded you are most likely indeed correct.It is indeed most Likely a connector problem on the board.Recently,While I was conducting a repair on An IPad Pro I accidentally removed a display flex cable too fast and it damaged the connector and now I am getting it repaired by a micro souldering shop near me.So I would suggest first trying to clean the phone up as from the photos the connectors look a bit dusty do not blow on it or use water You can instead used compressed air or any other approved cleaning method for electronics.If it still does not work you should take it to a local souldering shop to see if they can replace the connector on the logic board.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Joey будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 28
