PS5 disk drive not spinning full speed
My disk drive all of a sudden stopped took everything apart re aligned all the gears and mechanisms cleaned laser. Disk takes properly no sounds ejects fine but just will not read or spin to full speed it starts to but then stops any suggestions I have already done the normal repair issues found on the units mine seems to be something else
Это хороший вопрос?
Hi,
Don't know the PS5 but can you tell if the drive's laser lens is turning on at all?
Be safety aware and don't look directly at the lens!
if the drive starts to spin but no info is being read off the disc it might not continue.
Just a thought
из jayeff
Yes it turns on @jayeff
из Nick Nardini
@Nick Nardini
Have you tried restarting the PS5 in safe mode to help determine if it is a software or hardware problem? Be aware that you may lose data if you try this.
из jayeff
Yes before tearing into the unit I exhausted all the safe mode options @jayeff
из Nick Nardini
@Nick Nardini
Are there any error messages being displayed?
из jayeff
