Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281вопросов Показать все
Will replacing my logic board effect the data or usability of my SSD?
Hey everyone. I'm currently backpacking in Mexico and it appears that my logic board just crapped the bed on my mid 2014 MacBook Pro. I have a lot of files and information on it that I desperately want to keep. I know there is a way to extract the contents of the SSD using a storage enclosure but I'm wondering if I replace my logic board, will my data remain unchanged?? I'm considering buying the storage enclosure just in case but would prefer not to since it's extremely difficult to ship things to Mexico. Any information on this would be much appreciated!
Thanks!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi @sheacameron ,
The data on your SSD should remain intact. The SSD is removable from the laptop on the 2015 models. It is held in place by one screw. Make sure you disconnect the battery first before removing the hard drive!
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks so much! It sounds like this might not be the absolute travesty I initially thought it was as long as I don't break anything during the replacement.
из
Наиболее полезный ответ
It *shouldn’t* be an issue. If the actual SSD is still in working order, swapping to a new logic board would retain all your original data. Depending on what operating system that board last had on it, there may be some quirks due to firmware stuff. But realistically it shouldn’t be a huge deal. Especially if you keep it within the same model of MacBook.
Some models there is a little wiggle room to swap around between different years, if you have a mid 2014, the form factor remained largely the same in that time period at least amongst the 13” models or the 15” models (you definitely cannot swap between these two), but you may run into issues with compatibility of all parts if you switch years, especially if you swap forward to a 2015, where the display is definitely not compatible.
Оценка 1
2 Комментариев:
Excellent info, thank you. Mine is a Mid 2014 2.6 GHZ with 13" Retina and I plan on ordering the identical logic board from iFixit. I have been told by an Apple Tech that as long as I'm careful with the replacement, I should be able to just swap the logic board and everything will remain intact. Fingers crossed! Also, the SSD is still good. I was able to fire up the computer for about 10 minutes and transfer some files to an external HD before it crashed again (I know, probably very risky) but thankfully it didn't currupt any data on the external drive. Anyways, thanks for the info!!
из
This sounds like a solid plan on all accounts. Bummer your board died. Let us know how it works out!
из
Добавьте свой ответ
Shea Cameron будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 35
За всё время: 706
