Repair and disassembly information for Razer keyboards.
Is there a way to fix this connector?
My Razer Cynosa’s spacebar isn’t working. After a lot of trying out I finally found this connector directly conencted to the spacbar on the board. It seems that it is just not connected and therefore there can’t be any input from my spacebar. Now the question obviously is, if there is a way to fix this by myself. Thanks!
Here is the picture:
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
There are a few ways to try to fix this:
Fill the gap with solder (put solder on the broken track and take of the excess with solder wick)
Use conductive paint to repair the pad
Run a jumper wire from the cable to its respective pin on the connector
Let me know if you need more details.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks! This sounds good! If I've got any further questions, I'll get back to you :)
из
Добавьте свой ответ
Mattis Ba буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 182
