Repair guides and disassembly information for the Samsung Galaxy Z Flip3 folding Android smartphone, released in August of 2021.
Turning off when unplugged from charger
Hello,
I have a flip z3 and as soon as I unplug the charger it turns off, says battery 100 when plugged , but when unplugged just turns off, PLEASE HELP
Это хороший вопрос?
Счет 2
2 Комментариев
How did you solve this problem? I have phone with same error, eventually the phone shuts down as it close ...
из
i'm having the same problem. If plugged in, it works fine. You can open and close the phone and it will stay on. However, the second you unplug it, it turns off. It shows 100% charge. You can't get the phone to start again until you plug it in. Is this the same issue with the screen needing to be replaced? Seems like a dead battery. June 10, 2024 Jerry Ross
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Just received a customer's phone today which has the same problem. I opened the back cover and disconnect the FRC cable will solve this problem. After reading the service manual. The FRC cable is used for transferring signal from the USB board. I will try to replace the USB board and see what will happen
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
Do we have update? if the usb board changed will fix the problem?
из
did you repair customers phone?
из
After thoroughly test. It's caused by the screen flex cable that crosses up and down. When you move it like open or close the phone it will trigger a short on the circuit. Then the phone shut off by the circuit protection. It can only be fixed by replacing the screen.
из
Is this something that a Verizon store will fix or can I repair it?
из
@dickyliang is this something I can fix or do I need to go to the Verizon store?
из
Показать ещё 1 комментарий
Добавьте свой ответ
Alina Dumitru буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 37
За всё время: 5,862
