Power on but no image no sound
I found my old game gear, i forgot 2 batteries in.
A lot of acid come out on the motherboard i clean it with isopropilic alcool most corrosion is on the back of dpad, if i plug in batteries or the power unit the red light is on but no backlight no picture no sounds.
Any advices ?
Thanks
Это хороший вопрос?
Счет
0
Have you recapped this unit yet? Many Game Gears suffer from bad capacitors and the capacitors themselves can cause many problems.
из Andrew S
thanks for the reply, it is completely original, no work has been done on it
из Principe Motociclista
@Principe Motociclista Can you follow the Sega Game Gear Capacitor Replacement guide up to step 6 and tell me your version(VAx) and board number(837-XXXX)?
из Andrew S
