The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Вопросов 20 Показать все
Password digits 3,6,9,cancel not functioning
I replaced the digitizer about 18 months ago. It has been flaky ever since. I reopened it to see if I could fix this problem. Now the symptom is the digits 3,6,9,and cancel will not respond when opening password. This symptom is not now flakey but solidly not functioning. I thoroughly cleaned the connectors per your instructions. My question is, is it the digitizer or the processor. Any ideas?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Hey Chuck,
Seems to me like a logic board issue as concurred by @beanman56 . With that being said maybe there are dead spots on the screen which are causing this.
Did this happen after an update or did something happen to the device prior?
IMPORTANT NOTICE:
From Sunday Aus to Friday AUS, i will be unavailable as i am camping then.
Был ли этот ответ полезен?
Оценка 2
Its the digitizer
i’m 99.5% sure
Оценка 1
2 Комментариев:
Replaced digitizer same problem.
из
Sounds like its a logic board problem then :/
Like the software or something
из
Добавьте свой ответ
Chuck Porembski будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 140
