The Logitech M305 is a wireless mouse released in 2010. It is designed for ambidextrous use.
Why my Logitech mouse red light is flickering?
With time my mouse light is getting flicker. The cursor is shaking. Is it repairable?
Это хороший вопрос?
Счет 5
Добавить комментарий
1 ответ
Here’s what I found on a ‘dead’ mouse: The one lead of the LED had an obvious Dry Joint which I could pick up by visual inspection. Resoldering it made the mouse work again. I suggest you carefully resolder ALL the joint if the problem is not directly visible.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
N.Jaini буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 22
За всё время: 490
