Repair information for network equipment including routers, modems, and shared storage.
309вопросов Показать все
Tool to plug in to an ethernet jack to sense whether it is active
I don't know what to call this, and have thus far had no luck googling an answer. Ideally, I'd have a small meter that would plug in to a female RJ45 wall jack. It would give me a green light (or whatever) to indicate that there was an active network available.
There must be a tool that does this? What's it called and where can I find one?
Thanks.
Это хороший вопрос?
Оценка 4
Добавить комментарий
7 Ответов
Выбранное решение
if you are just looking for "hot" ports, where a router or switch is already in place, you just need something like this:
http://www.frys.com/product/3824317?site...
We use a spare IP phone where I work...
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
Perfect. This is just what I needed. Thanks.
из
Does anyone know if anything smaller exists? I remember a long time ago when I worked at a big networking center one of the technicians had a thumb-sized terminator on his keychain he'd just plug into ports to see if they're active. I'm looking for something similar.
из
Наиболее полезный ответ
What you're looking for is a Network Testing Device. I'm not sure what the price for such a device is, but I can guarantee you that it does the job. The tool that I've used in the past is a Fluke LinkRunner. Keep in mind this is a professional model, but there should be similar devices available.
Оценка 5
1 Комментарий:
Thanks, that would do it. I need something simpler. Might use this in the future, though.
из
Something like this http://is.gd/4Yvek is probably a little more cost effective if it is just for hobby purposes - A Laptop would also suffice ;)
Оценка 3
1 Комментарий:
This is good too. The laptop option is what I've been doing, but wanted something simpler. Thanks for the advice.
из
Bruce and David,
Hey, does that device have a mac address? or does it grab a dhcp address if available?
Ken
Оценка 0
1 Комментарий:
This must be the oldest question that was reawakened. It is 4 years old and Bruce and David have not been active in a while. You might want to try to ask your question right here
http://www.ifixit.com/Answers/Ask/Networ... :-))
из
u can use wireshark or Mot tester with sensor for activity
Оценка 0
I use one of these, but it only test 10/100 lines not 1000 Mbps lines.
https://www.amazon.com/Smartronix-Linkch...
Back in the day, I’ve made a few testers out of these as well. Soldered a push button and a battery inside.
https://www.revamp-it.ch/index.php/en/sh...
Оценка 0
What about a looop back plug?
Оценка 0
Добавьте свой ответ
Bruce Corson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 32
За всё время: 28,780
