Thread for questions about repair of the Casio PT-1 mini / portable keyboard, which I believe was originally released in 1985 (?)
Wondering why Casio PT-1 suddenly stopped working (won’t power on).
I have had mine since originally buying it new in the 80s. It worked fine until just recently when it stopped powering up. Unit is clean in very good condition so a bit baffled why it stopped working suddenly. I do not have AC adaptor and am using batteries. The battery compartment is also clean. I expect it is a small easily fixable issue so am wondering if anyone has experience with this / similar models and may have suggestions what to check and how to fix it. Thank you in advance to anyone who may be able to help!
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
I have the exact same problem with my Casio PT-100 I got at goodwill. Took it apart and found that the diode is completely broken off and missing. I am guessing the diode is your issue as well.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
ThomasF буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 496
