The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Do you have a Keyboard teardown guide for a MacBook Pro Early 2015?
I need to replace the keyboard in the MacBook Pro Early 2015. I am unable to find the teardown guide for this procedure. I would like to purchase the replacement keyboard but I need the guide so that I'm able to install it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
We don’t have a full guide going all the way to replacing the keyboard as its not something that a DIY should attempt. Instead we have this guide MacBook Pro 13" Retina Display Early 2015 Upper Case Replacement which get you down to the upper case which you can replace MacBook Pro 13" Retina (Early 2015) Upper Case Assembly for a lot less work and cheaper!
If you still want to replace the keyboard alone then you still need to get to this point. You need to first remove the backlight unit which is the thin black sheet covering the keyboard without ripping it. The next steps are quite brutal! As you’ll need to remove the screws and then ==pull the keyboard away from the frame snapping off the plastic rivets. The replacement keyboard should come with the self tapping screws to replace the rivets. You need to use care not damaging the case which is quite easy to do.
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly Изображение
Продукт
$269.99
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Interesting! If you're such an advocate for right to repair, shouldn't you have the teardown guide on your site?
из
@carroll - I'm a volunteer here on iFixit.
Replacing an assembly vs digging down is sometimes the easy and cheaper way. Don't forget I didn't design the computer! Only faced like you having to fix them.
The blame goes strictly to the fruit company here! The older Unibody systems used screws! So the keyboard could be replaced without manhandling things to such a degree. So what I preach is best for a DIY or even most techs as well.
из
Добавьте свой ответ
carroll будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 176
