Surface type cover not powering on and connecting to the computer
So…I currently use a surface pro 7+ for everyday and all of a sudden my keyboard stopped working (For context here’s a few things that are normal):
- Surface turns on
- Surface reaches login screen
- Surface logs in and is on home screen
- Surface is in UEFI bios
- Surface is in Advanced startup options.
In none of these scenarios does the keyboard work. No lights are on. No signs of life. However after a reset of windows it does work but then small things do trigger it to stop working again.
I have tried literally everything from cleaning the contacts to even (repeatedly) turn on and off the type cover port in the UEFI bios with absolutely 0 luck at all.
Pls help as this is a machine used on an everyday basis.
Thanks.
Update (10/04/23)
So, after going back and forth with Microsoft, the only solution they had was to send me a new keyboard, which now works fine.
Это хороший вопрос?
