Any ideas on placement of metal part during reassembly?
Basically dismantled the unit to clean as hair gets everywhere, a small metal part fell out before i had the chance to take a placement photo, and now can’t quite figure how it’s meant to realign. Everything else appears to be in order I just can’t place this small metal lever which I’m guessing is what closes the circuit.
Below is an image of the unit which illustrates the area where the black plastic switch is meant to slot in on the bottom of the image, along with the black plastic switch underneath the unit alongside the metal part that I cannot seem to place correctly. You can see the small metal solder on the bottom right of the motor unit, which i suspect may be what the metal ‘clip’ part is meant to close the circuit on:
Below are close ups of the actual metal part that I cannot fit correctly into the unit:
Below is an image of the black plastic switch in position within the unit:
Can upload more images if there is something specific that i need to include.
Это хороший вопрос?
2 Комментариев
hello Stripey , can you post a photo of this part?
из martin hoffmann
@behavintradie Hi, yes apologies i've just got my phone up and running again.
I can post more informational images if of use - please do let me know.
Thanks,
S
из Stripey Cat
