Where can I purchase a replacement battery?
I’m trying to find out where I can purchase a replacement battery for this device. This battery is in the device that my son uses for his insulin pump and we’re looking at taking a trip where the battery may not last long enough. We’ve got some other backup options (power banks) but since the battery already has a hard time keeping a charge I figured I would try to get a replacement for it as well. Attached below is a picture of the current battery, I’ve tried doing some searches but had little luck. Thanks!
Это хороший вопрос?
2 Комментариев
Hi. Is there any know solution?
из Rbvn
@rbvn Call up Omnipod and demand a replacement PDM. They should've sent you one already from the recall. If you just got your PDM, you might be in the clear.
The number is 1-800-591-3455
из Andrew S
