The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Uneven hinge retina MacBook Pro
So I just noticed that my MBP has sort of uneven hinge.
In the photo you can see that in ventilation it taperes from left to right. It is quite big difference and is bugging me so much. Screen works perfectly and hinge is stable as new one.
What to do? Thanks!
Это хороший вопрос?
Оценка 1
1 Комментарий
While it does look like the gap is different I can't tell what the issue its. When you close the display is the edge of the display even with the main case?
Does the display shift side to side when closed so a bit goes over the edge?
Lastly does the black clutch cover shift or appear loose?
Depending on what you tell us we can then figure out whats needed.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Take the display off and realign it. While it's off, adjust the clutch cover if needed.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jack A будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 160
