Starting up, beeps three times and shut itself off
I was playing in my PS5 and suddenly its fan started spinning really loudly and it shut itself off.
Now when I try to turn it on, it will beep 3 times and shut itself off.
Safe mode doesn’t work. It still shut itself off when I try to boot this way.
Some strange facts:
- As soon as I plug in the power cord in my PS5, blue light lit it self briefly
- It goes for a second or two the safe mode start screen, but then it beeps three times and shut itself off
- I try to turn PS5 in different ways:
** via HDMI connection.. —> 3 beeps and shut itself off
- Console power button —> 3 beeps and shut itself off
- Controller (wired and wireless) —> don’t even work!
I have seen an YouTube video with the very same issue saying that there might be a short in 5 volt lines, and in that particular case the fault was on the LED ribbon/board. (Video: https://youtu.be/0Lfq11qouPA)
Questions:
- Have any of you guys faced such issue? What was the solution?
- I have very little experience with electronics and I bet I couldn’t investigate the potential short, but having a look at ifixit tutorial on removing the LED Board, it seemed to me pretty reasonable. Does some one knows if I simply disconnect the LED ribbon if ps5 would work properly? (Assuming that this is the issue)
Это хороший вопрос?
did you unplug it and turn on to completely drain the power. it maybe a over voltage protection.
из stressmaster
